ZTW Seal 90A Boat ESC with 3A SBEC for RC Boat
Příspěvek od vroomok, 23 duben 2018 · 91 views
SEAL 90A SBEC 3A
Overview
We all know that that boaters crave for more power than cars and airplanes and ZTW has come up with a whole new way to put the power to the water – The new SEAL line water-cooling brushless speed controls for marine applications. ZTW uses new FETS that offer less resistance and less heat dissipated. Even so they added more water-pipes to increase the cooling area to dissipate the heat faster and better so as to bring a even more incredible power levels without any risk of frying the controller.
Well designed MCU with efficient code makes for faster sync and accurate control. Beside the performance they have also bring you a whole new fashion looking marine ESC.
freewing Rc airplane
Sunray SR4 800 hd se
FMS rc airplane
Kerui alarm
Freewing UK
This is their SEAL marine speed controller. Quality, performance and fashion are what they are all about.
Features:
1. Extremely low internal resistance
2. High efficient three pipe water cooling system
3. Super smooth and accurate throttle linearity
4. Over temperature protection
5. Auto throttle shut down in signal lose situation
6. Supports high RPM motors
7. Power arming protection (prevents the motor from accidentally running when switched ON)
8. New Advanced programming software
Specifications:
Continuous Current - 90A
Burst Current (10s) - 110A
Battery - 5-18 NC/2-6 LiPo
BEC Output - 5.5V/3A
Width - 66mm
Length - 33mm
Height - 23..5mm
Weight - 75g
more info: http://www.ztwshop.com
Září 2018
P Ú S Č P S N
     12
3456789
10111213141516
17 18 1920212223
24252627282930
Categories
