G-SHOCK FAQ
nAscA
1) JAK SE ZORIENTOVAT V NAZVECH CASIA - http://forum.chronomag.cz/index.php?showtopic=18579
2) VYHLEDAVANI G-SHOCKU
a) podle roku vyroby http://mygshock.com/wiki/List_of_Every_G-Shock_Model
B) podle modelu http://translate.google.nl/translate?u=htt...en&ie=UTF-8 (prelozeno googlem z japonstiny)
C) na ebayi http://www.g-shockzone.com/results.php?sea...at=watch*result
3) CUSTOMIZACE
- barveni pouzdra a remene http://mygshock.com/wiki/Dye_a_G-Shock a hoochyho navod http://forums.watchuseek.com/showthread.php?t=86046
- odstraneni barvy z pismen na pouzdru http://forums.watchuseek.com/showthread.php?t=68211
- negativni display http://forums.watchuseek.com/showthread.php?t=19275
http://www.google.com/translate?u=http%3A%...=en&ie=UTF8 (opet diky googlu prelozeno z japonstiny)
- pridani obrazku na display http://www.geocities.jp/murphy40jp/el.html
přidání obrázku na display:
http://forums.watchuseek.com/showthread.php?t=67671
http://forums.watchuseek.com/showthread.php?t=68162
4)RUZNE ODKAZY: ruzne navody (napr. jak nastavit Tidegraph, vymenit baterii a mnoho dalsich uzitecnych)
http://forums.watchuseek.com/forumdisplay.php?f=125
http://mygshock.com/wiki/Main_Page
Stranky, ktere doporucuji projit :)
stranky moderatora WUS a jednoho z nejvetsich (ne-li nejvetsiho) sberatele Gecek - Sjorse http://www.g-peopleland.com/
blog silence Sjorse http://50-gs.blogspot.com/
blog Rileyho http://mygshock.com/
stranky sberatele Neila: http://www.g-shocknation.com/Home.html
dalsi pekna sbirka http://www.h2.dion.ne.jp/~g2club/gs-new.htm (prelozte si pres google sami ;)
a jeste jedna http://www.g-shockcollector.co.uk/
stranka Adana http://telefonica.net/web2/g-stock/
http://sgshock.wordpress.com/
http://watchaday.blogspot.com/
http://www.altsnk.com/agoods/index.htm
http://geeshare.blogspot.com/
http://www.digitalwatchlibrary.com/
http://ww1.tiki.ne.jp/~tokio/tokio/g-shock/g-shock.html
Pokud jsem na neco zapomnel, budu rad, kdyz sem odkazy pridate.
PS doufam, ze to bude k uzitku, pripalil jsem diky tomu obed.
Upraveno uživatelem Gilius
  • Odpovědi 108
Co znamenaji cisla vzadu na frogmenech? (doted jsem taky nevedel, ani po tom nepatral, ale ted nahodou objevil)
Vysvetlil to Wah_Wah_Wah (no kdo jiny taky, ze?)
The serial number on all frogs has meaning.
From left to right, the first digit is the production year; the second is for month and the rest four digits are the real serial number.
For example: 501234 means issued in year 1995 (or 2005, you should have a common sense to guess) October and it is the 1234th frog produced.
For the second digit, N means November and D means December.
Sometimes you can use this number to check if the frog is a customized one or original. For example, all the DW-8200B-9A (Golden eye frog) were issued in 1995. So it must start with digit '5'.
BTW pokud by nekdo potreboval neco prelozit, tak to klidne udelam, nebo muzete pouzit http://www.google.com/language_tools?hl=cs
Upraveno uživatelem nAscA
Ty pokusy z WUSu jsou fakt děsný, ale kdyby se s tím člověk vyhrál, mohlo by to být ve finále i docela hezký. Dnes jsem si na zkoušku zkusil dát podtisk do podsvětlení 5600. Abych se dostal až k zadní stěně displeje, musel jsem je rozebral na prvočinitele. Docela mi zalepilo, když jsem je rozložil a vyskákalo na mě postupně šest prťavejch pružinek o kterých jsem si nebyl až tak úplně jistej kam patří ;) Takže jsem pro jistotu opatrně rozebral ještě jedny abych viděl jak je to tam poskládaný - výhoda vlastnictví více modelů z jedné řady :)
Pokus s podtiskem se víceméně povedl a potvrdilo se, že se na to musí fakt s citem. Načmáral jsem něco málo modrým a červeným lihovým fixem na průhlednou fólii a přestože stopa fixy byla hodně průhledná, bylo to místy až moc a displej byl dost nečitelný. Červený fix nepoužitelný, modrý jakeš takeš. Osobně si myslím, že by mohl být dobrý výsledek lejzrovým (a možná by stačilo i inkoustovým) tiskem azurovou barvou, a samozřejmě jen linky, žádné velké plochy. Bohužel barevnou tiskárnu teď nemám k dispozici, ale zkusím se k někomu vnutit (až tedy také seženu vhodnou transparentní fólii) . O výsledek se pak podělím.
Mimochodem, ty pokusy jsou na hodinkách se solárním článkem (můj případ) dost zdlouhavý. Nejen, že chvíli trvá to rozebrat a složit, ale tím, že se při rozborce odpojí baterka, tak se nejspíš vybije nějaký kondenzátor a hodinky po složení přejdou do režimu kdy nereagují na stisk tlačítka podsvětlení. Je potřeba je vystavit aspoň na půl hoďky na světlo a pak se teprv vzpamatují.
Dobre, pak se pochlub s vysledkem, jsem fakt zvedavy.
Ja se vcera snazil udelat negativni display na jednych Frogman, ale nepodarilo se mi ani otevrit screwback, jen jsem ho pekne doskrabal :wacko: , budu to muset dat k otevreni nejakemu hodinari.
