sureshot Odesláno 16. března 2010 Odesláno 16. března 2010 po steampunku v podani CABESTAN WINCH sa dnes na ablogtoread objavila info o Cabestan Nostromo Watch ktore su riesene v podobnom duchu Prices starting at CHF 150'000 FUNCTIONS ? HOURS, MINUTES, SECONDS READ FROM THREE ENGRAVED ROTARY DRUMS ? POWER RESERVE INDICATOR ON AN ENGRAVED ROTARY DRUM (50 HOURS) MOVEMENT ? FULLY MECHANICAL MOVEMENT CALIBRE CAB PG 160 WITH SWISS ANCHOR ESCAPEMENT ? FREQUENCY: 21 600 ALT/H OR 3 HZ ? 37 RUBIES ? BREGUET BALANCE-SPRING; MOBILE GENEVA STUD ? WINDING UP AND TIME SETTING USING AN EXTRACTING CROWN ? VERTICAL GEAR SYSTEM, HOLLOW BRIDGES, DRIVE SHAFT WITH CONICAL GEARS, SPECIALLY MACHINED BARREL ? SUPERLUMINOVA COATING INSIDE THE BRIDGES & WINDOWS, ALSO ON OTHER SURFACES ? FULLY HAND FINISHED: BEVELLING, POLISHING, DRAWING, GRAINING AND HOOPING CASE ? BLACK PVD TITANIUM CASE ? ONE FUNCTIONAL CAPSTAN WITH EXTRACTING CROWN & THREE ORNAMENTAL CAPSTANS ? TWO SIDE WINDOWS WITH SAPPHIRE CRYSTALS ? CASE BACK IN SAPPHIRE STRAP & BUCKLE ? FOLDING BUCKLE WITH DUAL CAPSTANS ? HIGH QUALITY TWO-LAYER RUBBER STRAP WITH BLACK SUPERLUMINOVA COATING chronomag 1 chronomag 2 Luxist ablogtoread
