Ohm-Aztec Odesláno 23. února 2015 Nahlásit Odesláno 23. února 2015 Technical detailsModel: Jaeger-LeCoultre Master Compressor Extreme LAB2MovementJaeger-LeCoultre 780 CalibreMechanical automatic movement developed and produced by the Manufacture Jaeger-LeCoultre? 569 parts for Calibre 780? Chronograph with large double-digit minutes counter? Crown selector and function indicator? Main time-zone adjustable in one-hour increments? Second time-zone (hour and 24-hour indication)? 180° radial 60-hour power-reserve display? Small seconds (movement operating indicator)? Independent stop seconds device? Nickel silver ebauche? Diameter: 33.8 mm. Thickness: 9.08 mmChronograph? Large twin-disc 60-minute digital minutes counter with built-in locking system? Eight-of-a-second seconds counter ? 24-hour display? Column wheel? Vertical coupling-clutch? Rubber-clad push-pieces and push-piece guards Function selector? Ceramic crown with integrated function selector push-piece? Column wheel-type selection system? Three-position indicator: 1. Winding, 2. Date and dual-time adjustment, 3. Time-settingEscapement? 28,800 vibrations per hour? Large variable-inertia balance (11.5 mg?cm2)? Balance with two pinning points with stud-holder locking plateAutomatic winding? Oscillating weight mounted on ceramic ball bearings, lubricant-free? Unidirectional winding? Three-spoke oscillating weight and platinum segmentCase143 partsDouble-ringed caseSpring-secured ceramic bezelSecure and ergonomic chronograph push-piecesSapphire crystal (caseback and dial) Materials, two versions:- TiVan15 (material exclusive to Jaeger-LeCoultre).Ceramic bezel and crown, rubber-clad push-piece guards.-18-carat pink gold and TiVan15 (material exclusive to Jaeger-LeCoultre).Ceramic bezel and crown, rubber-clad push-piece guardsDiameter 46.8 mm. Thickness: 16.5 mmDial and handsOpen-worked dial, black PVD-coated bridgesRaised function displayLuminescent hour-markersNew shape of open-worked handsStrap and buckle? Lever-operated strap interchangeability system? Strap held to 2 attachment points, triple-notch fine adjustment ? Secure double pin buckle with double-notch fine adjustment, built-in interchangeability system Zdroj: http://www.masterhorologer.com/2015/02/jaeger-lecoultre-master-compressor.html
JAJA Odesláno 23. února 2015 Nahlásit Odesláno 23. února 2015 Tak tohle se mi hodně líbí...je to trošku divočina. A pro pořádné chlapi... 46,8x16,5mm
Jumbo Odesláno 2. března 2015 Nahlásit Odesláno 2. března 2015 Tak jako původní model jsou zajimavé, ale dá se jenom těžko určit, co všechno a kde ukazují.
sashator Odesláno 2. března 2015 Nahlásit Odesláno 2. března 2015 Jak se mi líbí víceméně celá řada Master Compresor (hlavně Navy SEALS modely), tak toto (ala Hublot) je na mě už trochu moc....na druhou stranu kalibr je parádní, těch komplikací je tam požehnaně a jsou docela fajn vyřešené
JohnDoe Odesláno 10. března 2015 Nahlásit Odesláno 10. března 2015 Za mě hodně dobrý! Perfektní "moderní" hodinky, jen mi k nim nesedí ten kožený řemínek.
