People Odesláno 31. srpna 2014 Odesláno 31. srpna 2014 http://www.christopherward.co.uk/men/view-all-mens-watches/c11-cosc-ext-tkv-si.htmlTitanium is a chemical element (Ti) which was discovered in Cornwall in 1791 by geologist William Gregor. It is as strong as steel, yet 45% lighter and is highly resistant to corrosion in seawater which makes it just about the best case material possible for a dive watch.It's not only the case material, however, that makes the C11 Extreme one of the finest professional dive watches available. We have also engineered the case with a 4.3mm thick AR08 coated sapphire crystal to give water resistance for up to 1000 metres (nearly 3.300 feet) which puts this watch in a very small group of watches that have been watertight to this depth. The helium release valve integrated into the case is activated during very deep dives when the differential between the inside and outside pressure reaches a critical point, preventing the watch from exploding.Powered by a certified chronometer version of a Sellita SW200-1 automatic movement, adds all important accuracy to reliability.So, this is a watch that very serious divers need to safely perform under extreme depths. For the rest of us, it is a privilege to have the chance to own such a fine piece of engineering - especially one that looks as cool as the C11 Extreme! ?1,450.00 Non-EC Price ?1,208.33
