Snow Odesláno 24. května 2016 Nahlásit Odesláno 24. května 2016 SPEAKE-MARIN - Cabinet des Myst?res Skull Face to Face DIAMOND Tourbillon Red Gold Limited Edition NEW TECHNICAL SPECIFICATIONSSpeake-Marin Cabinet des Myste?res Skull Face to Face DIAMOND Tourbillon 18K Red Gold Case 42 mmFeatures and indications:? Central hours and minutes? Hand-finished 60-second tourbillon? White-lacquered, multi-level dial? Automatic-winding movement with 950 Platinum micro-rotor? Power reserve 72+ hours? 42mm Piccadilly case? Display backDial and hands:Dial made in 18K goldFinished in 2 tones, set with 8 diamondsChemically etched skull Central Speake-Marin signature ?Foundation? style hands in heat-blued steelMovement and finishing:? Calibre SM3Rhodium-finished German silver bridges? Glucydur balance? Automatic-winding movement? 950 Platinum micro-rotor? Diameter of rotor: 16.40mm? Single barrel? Frequency: 21,600vph / 3Hz? Power reserve: over 72 hours? Dimensions: 30.40mm x 5.40mm? Jewels: 25? 4N gold-plated bridge engravings:Twenty Five (25) Jewels60 Second TourbillonPlatinum Rotor MassSwiss Made; Speake-Marin Switzerland;Frequency: 3HzPower reserve: 72 hour Case:42 mmIconic Piccadilly case in polished 18K red goldBezel: ? Bezel set with 36 baguette diamonds (2.16 cts) ? Diamond set crown, round cut diamond (0.2cts) Front and display-back sapphire crystals treated with anti-reflective coatingCase-back circumference engraving: ?Speake-Marin ? The Piccadilly?Water resistance: 3atm/30m/100ft Strap:Hand-made, natural alligator strap Buckle:Pin buckle in 18K red gold The Skull Face to Face Tourbillon is a limited edition of 8 pieces. If skulls are part of the DNA of Speake-Marin for more than 10 years, it is the first time that the English watchmaker combines on the same dial, the skull theme with a tourbillon, mixing art and technicality. It is no coincidence if Skulls appeared many years ago in the Speake-Marin Collection. From an early age Peter Speake-Marin was fascinated with the subject and developed an affinity with the philosophy Memento mori. Memento mori is a medieval latin theory of reflection of mortality. It reminds us that life is short and that you have to appreciate every moment that we have. We have especially to do our best. The lyrics of this mediaeval music of the Catalan Vermell de Montserrat (1399) illustrate perfectly this philosophy: Life is short, and shortly it will end; Death comes quickly and respects no one, Death destroys everything and takes pity on no one. To remind that life if precious and every minute counts, nearly ten years ago Peter Speake-Marin decided to place skulls on the dial of the Cabinet des Myste?res collection. The collection holds a special place in the Speake-Marin watchmaking world. It tells the story of our founder, Peter Speake-Marin, through exceptional timepieces. From the most creative to the most complex complications, the Cabinet des Myste?res recounts the story of a modern watchmaker. Face to Face?s intricate double gold skull engraving has been etched onto the dial using a chemical etching technique. The two skulls are face to face to illustrate a reflection in time. The bezel is also set with 36 baguette diamonds (2.16 carat) an association with eternity, ?diamonds are for ever?. The Magister Tourbillon at 6 o?clock features a hand-finished 60-second tourbillon. Turning the tourbillon over, the movement featuring hand-finishing can be fully appreciated through the display back. Offset on the main bridge is the noble platinum micro-rotor, its strong and sober aesthetic counterbalanced by the intricate complexity of the tourbillon. The lower tourbillon cage is supported by a striking paddle-shaped bridge offering clear visual access to the surrounding gears below. The rhodium-finished German silver bridges and main plate are circular-grained with polished screw heads and polished countersinks. Technical details are engraved and gilded on the bridges either side of the platinum rotor. zdroj - http://watchesseven.blogspot.cz/2016/05/speake-marin-skull-face-to-face-diamond.html
Daemonultimate Odesláno 24. května 2016 Nahlásit Odesláno 24. května 2016 (upraveno) Z obecně kýčovité kombinace šutrů a lebek vylezly v tomto případě pro mne velice povedené hodinky, dokonce s minutovym turbem a mikrorotorem automatického nátahu, který s použitím platiny a zlata nenechává nikoho na pochybách o jaký a jak naceněný kousek se jedná. Třešničkou na pomyslném dortu jsou i v tomto případě modřené ručičky, které svým tvarem dnes již jasně signalizují o jakou značku se jedná a korunka ve tvaru diamantu s briliantem. Za mne hodinářsky i šperkařsky velmi povedený kousek. Upraveno 24. května 2016 uživatelem Daemonultimate
Kid_A Odesláno 28. května 2016 Nahlásit Odesláno 28. května 2016 Doufam ze se touhle cestou nebudou ubirat v budoucnu. Skulls uz je ve svete HH vic nez dost...
