Armin Strom Skeleton Pure Water
Návštěvník Snow
The Skeleton Pure is available in either steel (Water), 18K rose gold (Fire), titanium (Air) or black PVD treated steel (Earth).
Case dimensions are of the circular case are 43.40 mm diameter by 13 mm thick case, with the brand?s signature lip at six o?clock (which can be personalized with an engraving if you like). Polished to a mirror finish are the bezel, lugs and case flanks, whereas the back has a satin-brushed matte finish.
An open-worked movement can be easily done wrong but the depth of the Armin Strom caliber immediately pops out at you, especially because of contrast of blue and silver finishes. All visible through anti-reflective treated sapphire glass, front and rear.
Powered by Armin Strom?s manually wound in-house movement, caliber ARM09-S beats at 2.5Hz (18,000 vph), has 146 components (34 jewels) and double-barrels which provide a lengthy 8-day power reserve (192-hours).
Visually, the non essential elements of the main plate, gear-train bridges and barrel bridges have been trimmed away, revealing components such as the stacked mainspring barrels. Further, the main plate has a blue PVD coating that is colored to match its respective ?water? element (whereas the fire, air and earth models feature grey PVD treated main plates). The gear train and barrel bridges feature a rhodium (water) or ruthenium treatment depending on which variation you choose. Many of the bridges, wheels and other components have been decorated with a straight grained matte finish, providing contrast with the polished elements of the movement. Every component is hand finished, including hand bevelled edges for many of the parts.
Framed with a signature off-center clear sapphire dial ring , with applied hour and minute markers, the dial is readable without sacrificing the view of the movement. The small seconds indicator, at 9 o?clock, also features a clear ring. Remaining power reserve is indicated on the left half of the small seconds subsidiary dial, via a red arrow-tipped hand. A prominent hour and minute hands or in stainless steel (on the Air model) features white luminescent material.
Armin Strom?s Skeleton Pure collection is limited to 100 numbered pieces per variation (Water, Fire, Air and Earth). Each piece is individually engraved with ?X/100? is on the balance bridge. The Pure Water comes with a dark blue alligator horn-back leather strap with contrast stitching and a buckle, as well as an extra rubber strap also in dark blue. Water-resistance is 50 meters. The retail price is $33,400 is stainless steel.
zdroj - http://professionalwatches.com/2015/05/hands-on-with-armin-strom-skeleton-pure-water.html
Tak to se mi líbí. Promyšlený strojek s pérovníky, nepřeplácané zdobení, krásný tvary ozubených kol v celkově strohém podání, perfektně zvolené barvy. Skeletony nemusim, tyhle bych mohl a v poslední době nejsou jedinými. Ale zase jako vždy jen z říše snů.
